View the DvR routes (host routes and the IPv4 network routes) that are learned on a DvR Controller or a Leaf node.
Controllers display all the IP subnet routes configured for that DvR domain. Leaf nodes display the IP subnet routes learned from the Controller(s) for the Layer 2 VSNs in the DvR Domain. Leaf nodes also display any redistributed routes into the DvR Domain that are learned from the Controllers (direct routes, static routes and the default route).
Ensure that you enable DvR globally on the node.
- Select DVR.
- Select the Routes tab.
- Optional: To filter the rows based on the specific criteria, select Filter.
Routes Field Descriptions
Use the data in the following table to use the Routes tab.
Name |
Description |
DestIpAddrType |
Specifies the IPv4 destination address type of the DvR route. |
DestIpAddr |
Specifies the IPv4 destination address of the DvR route. |
DestMask |
Specifies the destination mask of the DvR route. |
L3Isid |
Specifies the Layer 3 I-SID of the DvR route. |
EcmpIndex |
Specifies the ECMP index for the ECMP routes of the DvR route. |
NextHopMac |
Specifies the MAC address of the next hop BEB in the DvR route. |
L2Isid |
Specifies the Layer 2 I-SID of the DvR route. |
VrfId |
Specifies the VRF ID. |
Cost |
Specifies the SPB cost of the DvR route. |
NextHopName |
Specifies the host name of the next hop BEB, in the DvR route. |
Type |
Specifies the route type of the DvR route. |
